RE: Eletronic engine syncronizer **SUPPORT **
I looked at the picture and I see what you are talking about. I was hoping someone else in the forums might chime in. How close can you get the sensor - an 1/8" would work? You could drill the hole through the fins rather than the hub then jb weld it in but should probably rebalance after that. The other thing is you can always put a small disk behind the prop and use the spinner magnets in the disc.
