need help
Impulse
I repeat DO NOT ATTEMPT TO START GLOW ENGINES WITH YOUR FINGER,
It is very dangerous , they generate enough power to cut your finger off ,
as for fueling , these tanks are fueled thru a tube , and caanot be poured , you can however use a squeeze bottle if that is all you have ,
as has been suggested , get what you can show up at the field anything you dont have someone else will , and most will be more than glad to lend and help you get started ,
Highlander
