RE: LED's & Runtime
mosiris,
I think I follow you, what you're suggesting is the EasyLights holding the signal line open on that channel? Whereas normally a servo would only send signal at the milliseconds it was used to control something, these are drawing power by holding open the signal line the entire duration?
That does make sense...although, they are designed to allow them to be controlled- as far as turning them on and off via the 5th channel on the CX2's transmitter. That will be my first test though....we'll see once I'm home. Thanks.
Derek
