ORIGINAL: dignlivn
Glacier Girl
You and sir raliegh both had great answers. As for the
Switch, What Amperage should the on/off switch be ??
I'm running 4s 14.4 volt lipos with a 60amp and also a 45amp
esc's. Thanks granite guy for a good question,btw.
Bob
dignlivn
Ps, I am running a 10amp switch in my 300 size heli, now
for 18 Months or so with No problems.
As to your question about the amperage of a switch, I'd pick a switch that will handle the maximum current you plan to use, in this case, a 60+ amp switch rated at 12 volts.
As you know, switches have an amperage rating based on various voltages. As the applied voltage goes up the current capability of the switch goes down, and vise versa. Just watch the current rating for a 12 volt switch (since that's as close to 14.4 volts as the specs will get) and reduce the amperage by 2 or 3 amps to make sure get what you need.
Now, this is assuming you'll be pushing the full 60 amps through the switch. If your system actually draws less, then a lesser amperage switch will do just fine.
