RCU Forums - View Single Post - Saito 72 big problem need help!!! Update...
Old 04-19-2003 | 04:20 PM
outssider
My Feedback: (23)
Default Saito 72 big problem need help!!! Update...
is the engine mounted inverted ? if so, this will make your idle mixture much more sensitive especially if the tank is a little high!
engine "bucking" at lower rpm ......especially saito's is a classic symptom of a rich idle mixture !
are you using a filter from the tank to the carb ? one tiny speck of dirt can ruin your whole day !
