Saito 72 big problem need help!!! Update...
The engine mounted on the side and as i can recall the main needle was opened 1.5 turn (that's quite sure ) and the idle neele between 2 - 3 turn from fully closed (counterside)
yes i do use brand new filter and the carb position is just or a little higher then tank middle line.
