RCU Forums - View Single Post - Saito 72 big problem need help!!! Update...
Old 04-20-2003 | 02:32 PM
Pepe J
Default Saito 72 big problem need help!!! Update...
Richard,
Just want to clear a little confusion here on the valve lash adjustment. I believe you are referring to .1mm (.004") and .04mm (.0016")
I knew what you meant!
In standard terms, one should be able to pass a .002" thick leaf between rocker and stem where a .004" will not pass.
Happy Fly'n....
