RCU Forums - View Single Post - Saito 72 big problem need help!!! Update...
Old 04-20-2003 | 04:11 PM
rcFp
Default thanks ...
The valve clearance was adjusted by one of the senior members so 0.01 mm supplied filler just got in the gap with a tinny bit of a slip. at this point when i rotate the prop manually i can hear metal knocking noise (good/bad ?).
other then that i use master airscrew balanced wood prop.
what do you thinks guys a about wrong/unbalanced shaft
thanks
