RCU Forums - View Single Post - Saito 72 big problem need help!!! Update...
Old 04-20-2003 | 09:06 PM
David Cutler's Avatar
David Cutler
Default Saito 72 big problem need help!!! Update...
Sounds like you have adjusted the idle jet too rich to compensate for air leaking into the intake tube.
Saitos do sometimes suffer from a leaking joint between the inlet tube and the carb or cylinder, due to the rubber 'O' rings not doing their job.
Try replacing the 'O' rings
David C.
