RCU Forums - View Single Post - VX.18 compression good or bad ?
Old 02-13-2008 | 08:13 PM
Macanan's Avatar
Macanan
Default VX.18 compression good or bad ?
Okay as we all know I mod the sleeve of my motor, which I had the electric start back plate on, do to the spring on my pull start sprung out, but I have since fixed the spring while waiting on parts to arrive and put the pull start back on, now when I pull the cord it seems like it has a lot more compression then before and I mean A LOT, you know like when you get more fuel in the motor and it seems like it wants to lock up when you pull the cord, so you have to remove the plug and drain what fuel is in the head ? well its almost like that but not as bad, is this good that it has this kind of compression ? like how you bore out a car motor and it rumbles like it's misfiring do to the high compression, I hope this is good and adds a lot more power to it, but what do you guys think ? I can't run it yet till I get the rest of my parts in and put back together. Thanks guys
