RCU Forums - View Single Post - LT-40 Nose Wheel
Old 04-19-2003 | 05:20 PM
NCLights
Default LT-40 Nose Wheel
Either I am the weakest man alive, or something is wrong. I'm on the step where you put the nose gear wire into the nose gear bearing and steering arm [which you place between the two excrusions on the nose gear bearing]. I finally gave up trying to push, and unscrewed the bearing from the firewall and tried to pull the nose gear wire out...No luck. The steering arm is too tight, and I can't get it out. Any good advice for how to get it off, and when I have to do put it on again, what should I do to get it right? Thanks!
