RCU Forums - View Single Post - Everything Radial Engines
Old 02-14-2008 | 03:05 AM
  #1207
Sandman Norway
Default RE: Everything Radial Engines
Hi Guys..
I need som help... I looking into using Soloprop on my Seidel ST-770. this has turned out to be kind of difficult due to
the spesial prop hub used on this engine. The ST-770 has a 16mm multibolt propshaft adapter, and this does not work with the
Soloprop hub. The Seidel hub i easy to remove. The propshaft itself is 10mm x 67mm, so my plan is to mill a key(woodruff) in the shaft, and turn a new prophub. Converting it to a singelbolt configuration, like the ST-710.
Now, it would be very helpfull if anyone of you that have the ST-710, could take measures of theire prophub, and shaft..
I see that Gnome uses the Soloprop, so if I could duplicate your set-up it would be very nice..
Thanks in advance..
Mfg Sandman
