Trouble with Quadra 35 (Update!)
rebuild the carb it may need a diaphram kit
also check ignition timing seeing as you had the engine apart.
if the timing is off you may be getting detination
If the engine isnt tuned properly wich all of the above will effect itll jump around and shake like a bugger.
