Trouble with Quadra 35 (Update!)
Old Quadras have points under the flywheel..You could remove the flywheel and check the points and point gap..The gap is cast into the plastic cover over the points....The wrong gap will affect the timing.....If it's too wide the timing will be retarded.....
