RCU Forums - View Single Post - AXE CP Receiver connections???? Help!
Old 02-14-2008 | 06:44 PM
Shadow99
Default RE: AXE CP Receiver connections???? Help!
You'd have to use the Spektrum receiver, AR6100 or AR7000. Plug the BINDING PLUG into the BAT terminal on the RX, press & hold the BIND BUTTON on the back of the TX while turning ON the TX, now turn ON or plug in the power to the RX, (if your using an ESC or 3in1 to power your RX, be sure to unplug the Main motor & tail motor leads to keep rotors from spinning), LED on RX will flash then go solid, when it's solid TX & RX are bound.
Shadow
