RE: CMP Zero Makeover
MSC, I located both servos in the actual horizonal stab itself, i used the DS 821's from JR and they still fit, now if i could go back and do it over, i prob woudln't hesistate putting the servos in center of the fuse more towards the CG. That way you won't have to worry about adding weight to the nose like I did. But when you get the plane, you will notice that hatches have already been cut to mount the servos in the horizonal stab, makes it look clean as well. Let me know how your progess comes around!
Bubs
