RE: controler not working HELP
You have to calibrate in window..otherwise Window won't recognize any signals for any games, sims, and etc.
FMS runs in Window. This is where you can calibrate a gamepad to act more like your TX....by taking out
the gain , adjusting the exponents or sentivities...because Gampads are more sensitive than a TX.
Then calibrate in whatever software or sim you're using.
Kind of like programing your Computerized TX. Another way to make a model less sensitives for new comers
is to adjust the gain cruve in your TX. Make the sticks less sensitive at center...not just the expos (max throw).
In a computerized TX..you can also adjust the expo only on one side of the stick. Very useful when adjusting the throttle
but also useful when you get a model that rolls more on oneside than the other.
In a none computerize TX, when you adjust the expos..it's for both side of the sticks.
