RE: HiTec RX
As said, only Futaba has the band issue and even then the newer Futaba receivers have done away with that.
I like the Hitec Receivers. I use them alot with my Futaba TX.
Make sure if you get one that it is compatable.
Some Hitec receivers are set shift. Some are selectable shift and some are auto shift. Selectable and auto shift will work with any 72Mhz transmitter.
