RCU Forums - View Single Post - J-35 Draken build thread
Old 02-15-2008 | 02:46 PM
  #58
Frank Alvarez
Default RE: J-35 Draken build thread
More pictures of the very time consuming cutting and corect alignment of the speed brake doors.
The geometry of this consistant curve of the inner fuse caused some rather heavy head-aching! I had to go thru several design applications (that incidentally failed) until I was able to find a solution to this tough application.
My dear friend Kerry Sterner, came to my rescue as he has faced similar frustrations with other aircraft in his time.
Thank you Kerry for your advise and patience while I trudged thru this hurdle
ID:	879366   Click image for larger version
ID:	879367   Click image for larger version
ID:	879368   Click image for larger version
ID:	879369   Click image for larger version
ID:	879370   Click image for larger version
