RCU Forums - View Single Post - Major glitch with AR9100: switch shortcut
Old 02-15-2008 | 03:52 PM
Vincent's Avatar
Vincent
My Feedback: (61)
Default RE: Major glitch with Spektrum system and jets
Mine is 19.5lbs with 65 sucessful flights on spektrum 10x module system and P-60 power. The jet can bite you VERY quickly if you are not paying attention.Sorry to hear this, your jet is awesome.
BTW: i probably would have not have located my rx there with the antenna wire almost touching the pump. My ecu is forward in the nose and i located my pump between the saddle tanks along side the UAT. My AR9000 is mounted on the fuse side very close to where yours is with the two satelites under the canopy one forward and one directly behind the canopy opening.
V..
