RCU Forums - View Single Post - Engine Mounting Thrust
Old 04-20-2003 | 03:23 AM
Highlander
Default Engine Mounting Thrust
NCLights
would that be to the left facing the engine or would that be left like you are sitting in the cockpit ?
Highlander
normally about 2 degrees of right thrust is all that is needed to compensate for torque , and washers are a good fix for that it doesnt hurt to have a little down thrust also .
but before you fix it make sure its broke if you know what I mean ,
what kind of plane is it ?
Highlander
