RCU Forums - View Single Post - Battery Question
Old 02-15-2008 | 09:07 PM
airbusdrvr
Default RE: Battery Question
If by "wall charger" you mean the type that comes with transmitters with the servo type connection to also charge your battery and if your battery is compatible with that voltage(most likely 4-cell) then you "could" charge the battery with it. You would need to leave it plugged in for a good while(depending on mah rating) to charge a compatible battery. You would, however, not know if the battery took a full charge. You would not have the capability to discharge the battery to see if it discharged near it rated capacity and then recharge it and see that it accepted a full charge. If you do charge it this way for this weekend, try to use a voltmeter with a load(I use a one amp load) to see if the voltage stays up during the test voltage check.
