RCU Forums - View Single Post - saito 91 intake push rod doesn't move.
Old 02-16-2008 | 10:04 AM
DarZeelon's Avatar
DarZeelon
Default RE: saito 91 intake push rod doesn't move.
ORIGINAL: skyratcalls
...The little mark on the cam goes straight up at top dead center right?
ORIGINAL: w8ye
...The timing mark can go up or down @ TDC it doesn't matter.
Explanation, Jeff.
The camshaft rotates once per every two rotation of the crankshaft.
So, if you installed the camshaft with the timing mark straight-up and rotate the crankshaft one full turn, the timing mark will now be straight-down (Vice-versa if you start start straight-down...).
This is why either of these two exact positions is correct.
But dare not place the timing mark to either side of these two positions... The easy-to-solve problem is that the engine would just not run... The worse problem can be piston-to-valve clash...
...You don't want that, believe me...
