RCU Forums - View Single Post - Everything Radial Engines
Old 02-16-2008 | 02:17 PM
  #1218
the Gnome's Avatar
the Gnome
Default RE: Everything Radial Engines
Hello Sandman, here the pictures of the spanners and the hub. The hole in the hub is 13mm diameter and 3.7mm deep, the hub is 8.6mm thick. I bat the dimensions are quite the same as on the ST 770 prop hub!
gnome
Holm und Rippenbruch
ID:	880308   Click image for larger version
