Gnome: Thanks bigtime...
I was s little supriced that the rear hole was cylindrical, on my ST-770 here are a conical split ring both in the rear and front of the hub, and the holes are allso conical..
If you haven`t all ready assembled the hub-prop assy, could you verify if the propshaft is identical as my 770.
Total length :67mm, 18mm treaded and 10mm diameter.
I think that I will make my own hub, it would properly be more easy that ordering on from Seidel :-)
If interested in following my progress on both the Sist FW-190, "working" guns from Maxotronic, and Seidel radial please take a look:
http://forum.paulsenbrudvik.com/index.php
You have to register to view the pictures, and most is in Norwegian jibberish. All information on the Maxotronic guns, are kept in English..
Thanks again Gnome...
Mfg Sandman
