RE: Brison 3.2 Carb Help!! (Where is Ralph when you need him!)
I took the metering needle out of the carb---Blew carb cleaner through it and even shot carb cleaner from the inlet nipple through the metering circuit---The needle moves freely---Unless there is some crud around the needle's seat that I can't see, I'm baffled as to why fuel still drips from the carb...
I'll strip 'er down again and see what I come up with---And rebuild it with new parts---Thanks for all of your help!!!
Kevin
