Covering a one piece plane is......
They are fun to try and hold without crushing, breaking, some part as you pull and tug on the monacote. Trying to get the iron into the corners and to ge teh covering to go around compound corners is just so much fun.
I have said that different colors react to heat in a different way. Red does not streach as much as White does. Dark blue is stiffer then Sky blue. So I know what you are saying about teh Pear White. Metalics are also different from the solid colors.
I just covered my Curare and the tail is built right along with teh fuse so it is 1 LARGE piece to swing around and try not to knock stuff off teh bench, break, dent, or other wise damage while working on it.
Just take it slow and easy and you will get it done.
Dru.
