RCU Forums - View Single Post - Capacity of NiMH batteries
Old 02-17-2008 | 08:44 AM
acarter's Avatar
acarter
Default RE: Capacity of NiMH batteries
The elite is set to discharge to 1.1v per cell which is as low as any reciever will work for. It is set like this so you can get a rough idea how many flights you can get. To find out how many mah you battery has you need to set the discharge to .9v per cell which is as low as you can safely go with your battery. This will give you your full mah rating.
Austin
