RCU Forums - View Single Post - Lipoly and speed 400
Old 02-17-2008 | 09:58 AM
Leo L
Default RE: Lipoly and speed 400
I presume that when you shut everything down and start all over again, the same thing happens. The most likely problem is that you are exceeding the amperage rating of the ESC and the ESC is shutting you down. If you want to fly with this motor/battery/prop combo, you need to increase the size of the ESC.
