RE: The best 50cc class import engine ???
IN OUR DEFENSE
We made no claims that we are using any aerospace materials in our manufacturing of the engine.
How many bikes have you seen with our engines in whole on them?
Milton has tested and sold the MT42 with no problems with the engines
Milton has tested and sold the MT 62 with no problems with the engine
Milton has run tests on the MT50 and it did not meet with his expectations and gave up early and went on to another make 50cc engine.
We got the MT50 engine and although it is of fine quality, in material and workmanship it needed to be fine tuned to get it to perform.
We started with 6200RPM out of the box and with changes in tuning we have it at a respectful 6850RPM with a Vess 22A prop, getting stronger with being broken in. There IS NO ISSUES WITH THE LONG BOLTS!!!!! After having run 3 gal. of gas. Running up to temp stopping to cool and repeat cycles, of hot to cool many times. After sufficient time I can see it turning a reliable 7000 RPM. with a 22” prop.
There was an issue with the MOUNTING PLATES on the MT42 and they are being replaced with a new material. Broken plates can be from many factors, some being the fault of the person mounting the engine.
Milton has some new plates coming his way to replace any bad ones.
There is a difference between having a problem with a product and having a problem and DOING SOMETHING TO CORRECT IT.
Every engine out there has had some type of issues with them in the infant stages, the difference is taking care of the issues and going on.
Until we are sure that any issues that come up with our line of engines we will Check EVERY ENGINE before it goes out the door. This will minimize any problems and also remember we are selling on a MONEY BACK if not satisfied basis.
Ralph Cunningham has had our engine for over a week and is testing and making recommendations, when he is complete with his findings he will issue a report. So far all his feedback has been favorable.
Remember we are a phone call away for support when you buy from us.
Questions before you buy will be handled by e mails. Feel free to ask.
Larry LS PRO ENGINES
AIRBORN RANGER
