RE: IMAC "BOX" SIZE
There is no box. You now get points for "Airspace Control". Check the sequennce sheets. It sound like you are going to two extremes -- too close, then too far out. You have to find a middle ground that will present the sequence so it will appear smooth and not rushed, but close enough to give good visibility. If you can't see what the plane is doing, neither can the judges, which means lower scores. Its VERY important to "draw lines" between each manuver. Failing to do so will also result in downgrades. Throttle managemet is imperative. Using a lower throttle setting on the horizontals will give you more time to get the best placement for the next manuver, and allow the judges time to get a score down. The judging schools are great and will help you understand what its all about. Most importantly, have fun.
