Hello All,
Well I bought a used lst2
and finally got it running. The first problem I found is that the slipper clutch was way out of adjustment and would not stay in adjustment, so I went to my local hardware store and got a new lock nut, that fixed that problem. Second problem the fuel tank will not prime, still have not figured out why. Third lost radio contact with it[X(], I found that the person that sold it to me had trimmed the ant to fit within the ant tube what a dumb ***** [:@]I thought to my self. After changing the radio out I finally got to play a little untill out of the blue I broke my front steering block [:'(]and I was only doing wheelies. My question is what normaly breakes? I heard that the steering blocks are one of the weak links is this true? Also what would you recommend I beefup? I was thinking RPM A-Arms with Integy ALUMINUM sterring blocks. But Please let me know!! For all of you the reason why I got an LST2 is because I'm tired of fixing my T-Maxx and heard that this truck is the ONE and ONLY true basher.
Thank you
Jason Evans
