Bucker Jungmann Rollout
The Bucker is a great airplane, and I can't figure out why Lanier doesn't bring it back out. By the way, for those of you about to build one, measure your wing plan carefully.....the left wing drawing was about 1/8 or 1/4" shorter than the right one....I found this out when I cut all the spars off the right panel, and they didn't fit the plan when I started on the left side!
Also, you can get the forward deck in fiberglass from Stan's, including the canopy if you just want to paint it rather than have it clear. The glass holds up better than the clear plastic does out here in the desert.
Clair
