RCU Forums - View Single Post - Plastic servo arms?
Old 02-17-2008 | 09:11 PM
seanreit's Avatar
seanreit
My Feedback: (60)
Default RE: Plastic servo arms?
That's the problem, the hanger 9 metal arms are not uniform across the board. Some fit perfect, some don't fit perfect. You are not losing your mind!
Some were loose and produced slop. I quite using them when I had to buy 4 to get 2 to fit right. Can't speak for any other metal ones although the SWB ones seem to be good, but I don't like them for the same reason Harley doesn't, you can't use a clevis.
By the way Harley, next time you won't strip the spline, you will break the gears in the Servo!
I've said before, I felt vindicated when they started shipping the HD plastic with the 8711 which is essentially JR saying this arm will hold up to 400 oz torque. Some people thought I was nuts when I was putting them on an 8611. Thought I would break it. I've done my own load tests, it's strong!
