RCU Forums - View Single Post - Ducted fan question
Old 02-17-2008 | 09:14 PM
Thud_Driver's Avatar
Thud_Driver
Default RE: Ducted fan question
Your tuned pipe needs a pressure nipple like this:
http://www3.towerhobbies.com/cgi-bin...?&I=LXNFB2&P=7
You need to install it just aft of where the pipe reaches it's maximum diameter - just aft of the bend where it goes from an expanding tube to a constant diameter tube.
Best if you can find some way to build up the area that you drill & tap into so there's more than just the skin of the pipe holding it in.
If you are using a silicone coupler like the one in the picture you will probably have to replace it often. Be sure to clamp it down well or the pipe & header will slide apart.
