3W 100 sputtering
Sometimes the little leve that lifts the inlet needle gets bent...It should be flush with the casting just next to it..Be sure you get the fork in the diaphragm hooked into the lever, if it has that type...Also the gasket goes against the carb, with the diaphragm on top......
