RE: spark plug falling out of zdz 80???????????
Once the threads get damaged from vibration when the plug gets loose, typically it will need an insert installed or a new cylinder and ring installed.
The spark plug should be checked periodically for tightness. We recommend 15-17ft.lbs with clean and dry threads.
