Hey guys, I am building a small 26 inch wing span cessna 150.
It shows it can use a rubber band. or a .049 cox nitro motor
I want to do it electric. its larger then it seems to me
I wanted to know what brushless motor would be good and what KV rating for 2s lipo?
and size of prop
Here is the motor i think should work but might be to much ? it will fit it in the nose of the plane, then i have 2 HS55 servos for it along with a Hi tech micro receiver.
as for the battery i was thinking a 500 Mah 2s should work.
http://www.hobbycity.com/hobbycity/s...idProduct=5430
http://www.hobbycity.com/hobbycity/s...idProduct=5464
