RE: Servo reverser interference
The flutter only occurs on the same side that the servo reverser is on, on the y harness. The other elevator side is rock solid. I don't think this is a reciever problem. It is with the reverser. I have read several bad things about reversers. I don't want to take the chance of loosing this plane, so the reverser is going to be taken out. I'm wondering if I just used a regular Y harness and reversed the wiring internally, maybe that would solve the problem? Hitec gives the instructions to do this.
Any help would be appreciated,
Brad
Q. How can I reverse the direction of my analog servo?
There are four wires that must be switched in order to change the servo direction. Two are on the motor and 2 are on the potentiometer. Switch the red and green wires on the pot and the orange and brown wires on the motor.
Hitec provides these instructions for information purposes only. Hitec assumes no liability when modifications are made to servos.
