RE: strip aileron flutter avoidance
Hi!
You could shorten the ailerons slightly 100mm at the tips ...but this is not necessary if you just are certain to make the aileron linkage sloop free.
What I react too though is your plan to use a 10x6 prop on that pattern airplane...it will not work too well, as it will produce a lot of noice and no peformance.
Better use a 12x6 or 11x8 APC or RAM prop. A 11x8 or 11x7.1/2 prop was size to use back in the "old days".
