Troy
Any setting up tips for this model, In particular C of G. I assume you left the wing incidences exactly as set up on the model. Also engine thrust. Using the YS 170 Mount the spinner is not flush with the nose ring. There is a bigger gap at the top of the nose than the bottom (altho' I notice on the Naruke website the gap is bigger at the bottom of the spinner -
http://homepage3.nifty.com/naru/page038.htm ).
Zi Chun Lin
Where did you get the model stand?
Brandon.
