RCU Forums - View Single Post - combat prop jets
Old 05-09-2003 | 01:31 PM
Demon
Default combat prop jets
Originally posted by OCTANE75
Any semi scale-scale combat propjets.
What are you calling a "propjet"?
Do you mean a scale model of a modern fighter (like an F-15) with an engine hung on the nose spinning a prop to be used in R/C Combat?
If so, then the answer to your question is no (at least I've never seen one anywhere).
RCCA Scale Combat limits designs to the 1935 - 1955 era. While there are plenty of jet fighter designs to chose from that were manufactured during those years, most are too small within the scale requirements (1/12th +/- 10%) to be competitive. Gus Morfis has (had?) plans available for a few Korean War era jets.
If Open class is the intended use of a "propjet", most jets also have swept wings. Streamers slide off of swept wings making cuts harder to achieve.
Bottom line: Semi-scale, jet type designs aren't very competitive in R/C Combat regardless of the class being flown.
Besides all of the above, jets are for kids.
D
