RCU Forums - View Single Post - Help - Warped fuselage
Old 04-20-2003 | 08:53 PM
CafeenMan
Default Help - Warped fuselage
After you have it like you want it using the suggestions above, you can use a fan on low to gently speed up the drying. But DO NOT use heat or you'll have a worse problem than you started with.
