Hinges?
OK- I'm using DuBro hinges in my 8' balsa B-2 bomber. #1-Should I install hinges before or after covering w/Monocoat. #2-If I closed up a space without putting extra balsa behind a 1/4" wall will pins be enough to hold the hinge securely? The a/c will probably be a slow flyer. Thanks for any help.
