RCU Forums - View Single Post - CMP Zero Makeover
Old 02-18-2008 | 09:48 PM
  #116
MSC
Default RE: CMP Zero Makeover
Bubs,
Got the plane and I see what your talking about with the elevator set up. Not sure if I'll go ahead with mounting them on the cg or not. I am moving the rudder servo to CG and use a pull pull system. I'll hook up a wire set up to the rudder and run it into the fuse. I should be able to connect the tail wheel set up connected to the rudder horns.
I will use a DA 50 up front and have purchased robart 671's struts. They are on back order so not sure how long it will take to come in.
Here are a few pics getting started.....
MSC
ID:	882741   Click image for larger version
