RE: Wood props on SP series?
Hi Jim
We always use and recommend glass composite propellers, however wooden propellers can be used if necessary and have been used in some RCV testing. It is important however to use good quality/heavier wooden propellers because generally wooden ones are too light and do not produce the flywheel effect. A point to note is that RPM figures will be lower when using wooden propellers.
Best regards
Stephanie
