RCU Forums - View Single Post - Everything you want to know about electric flight
Old 02-19-2008 | 09:03 AM
aeajr's Avatar
aeajr
Default Everything you want to know about electric flight
Note that even though this was originally posted in 2008, the articles get regular review and updates to keep them current.
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
An E-Book by Ed Anderson
Updated March 2015
PREFACE
A number of people have suggested I write a book on the topic of electric flight. I would, but I find the electric field is changing too fast. Paper based books go out of date too quickly. Instead I am going to create a thread that is my version of an e-book on the subject of electric powered flight. This e-format allows me to provide updates and to answer questions, things I can't do in paper form.
Whether you are a new flyer, a wet fuel pilot, or a glider pilot who wants to add an electric motor to your glider, I hope you find value here. Of course, I will fail to live up to the title as you can't know everything, but I will try to hit the essentials. I am also going to provide an index for your convenience.
The principals of weight, lift, drag, stall and all the other things we know about flying apply the same regardless of what motor or engine the plane may have. The power systems may differ, and each has its unique benefits and quirks, but the principles of flight remain the same.
For new pilots who have no background, just relax, breath deeply and read. I have tried to put it all in one place for you. Don't expect to know it all in one reading. After you take your early flights, come back and read again as you will now have some real life experience to compare to what is contained here.
If you are starting with an RTF electric airplane, you really don't need to know all this stuff. However be sure to look at the articles on RTFs and the Six Keys to Success for New Pilots. I think you will find them helpful.
For wet fuel pilots coming into electric, the first problem is terms and their meanings. The first two articles are specifically focused on this need.
I want to change your question from "What is the electric equivalent of a .40 glow engine?” to "What electric power system would be right for a 40 size glow plane?" The first question is VERY hard to answer, the second is not. I am going to ask you to put aside what you know of wet fuel systems and look at electric power with a fresh mind.
Electric motor systems are both simpler and more complex than wet fuel systems. It is just a matter of looking at them in terms that make sense for electric power and not trying to make them fit the wet fuel framework.
What about batteries? How do I choose between NiCd, NiMh, Lipo, and others? We will cover that.
Battery chargers are a mystery too, yet they are an integral part of electric flight. We will cover those.
What about tools to tell what is going on in your electric power system? Yes, we will cover that also.
I will be adding new chapters and topics, so visit again, you might see a new topic that interests you. And don't hesitate to suggest topics that need to be covered.
I invite others who have experience in this area to add their knowledge and become co-authors of this e-book. If you have an area of expertise, share it with us. If you come across a good discussion or a reference source somewhere, post a link to it and tell us why you found it helpful.
You will find my articles and posts rich in links to other resources. Be sure to take a look.
If you have a question, by all means ask as others will have the same question.
I hope you find this helpful. I hope you will contribute your knowledge as well.
TABLE OF CONTENTS
Post# ..... Topic
1 ............Preface
2 ............Amps vs Volts vs C
3 ............Sizing Power Systems
4.............Props vs. Amps
5 ............What is an Electronic Speed Control? - Amended 11-2008
6 ............The LVC, Low Voltage Cut-off
7 ............Who Needs a Wattmeter?
8 ............Why Use a Gearbox?
9 ............Extended Flight Times and Balance
10 ...........Battery Basics
11 ...........Lithium Batteries, Chargers and Balancers
12 ...........Six Keys to Success for New Pilots
13 ...........Things to Check on an RTF
14 ...........Now it is Your Turn!
15 ...........The Role of the BEC in Your ESC
16 ...........The Mythical Best First Plane
17 ...........What You Need to Know About Receivers
18 & 19 ... Radio System Basics
20 ...........The AMA Park Pilot Program
27 ...........What Goes on Which Stick?
45 ...........What Do Motor KV Ratings Mean?
81 ...........A Downloadable and Edited Version of this e-Book ( editing by Ken Meyers )
..................The .pdf is current as of 2009 and does not contain any updates after that.
139..........Estimating Battery Run time
170 .........How to Select Your First Radio
175 .........Basic Servo Set-up Process
As the book has progressed, I have expanded the range of the discussion beyond strictly electric topics but I have tried to stay within those topics that I feel are are relevant to electric flyers. For example the electric "parkflyer" class of planes has a large number of rudder/elevator/throttle planes. As pilots move from 2 or 3 channels to 4 channel planes sometimes people get confused as to were the rudder should reside on the radio. The article at post 27 addresses this question.
Post 139 addresses a question that comes up over and over related to kV. and 170 talks to the subject of picking your first radio. Note that this is slanted to electric and glider pilots more so than to glow or gas pilots but the content should be of interest to any new pilot.
Looking back, I would have organized the chapters/articles in a different order, but I am not going to trash the thread to do it, so I hope you will not find it too confusing as it appears here.
This book also appears on www.wattflyer.com. The chapters are the same but their numbers are different as the discussion has progressed differently over there.
JanErikV (04-06-2020)
