Kill switch help
Hello, I am wanting to hook up two kill switches for my mag. G26. I plan on having a manual switch and a servo operated switch. I plan on using the heavy duty slide switches from Radio Shack as they come two in a pack. Each switch has two terminals and I wanted to check to see if my plan for hooking them up is correct.
From what I understand, I need to run a wire coming from the black wire of the motor to the first terminal of the first switch, then run a wire from the second terminal of switch #1 to first terminal of switch #2 and then a wire from terminal #2 to a ground on the motor. I know that this sounds kind of confusing but is this the correct method for installing these two switches?
