RE: 480 Park motor problems
Check it over thoroughly. You may have bent the shaft, damaged a bearing, busted a magnet loose or damaged/deformed the actual bell or motor housing (and now it is rubbing) when you crashed it.
Take a close look at the wires and make sure you don't see any bare wires showing through.
