RCU Forums - View Single Post - Jetcat ecu setup for atv
Old 02-19-2008 | 12:28 PM
KC36330
Default RE: Jetcat ecu setup for atv
you should set your travels to 100 +/- and set the failsafe with them at this ATV. you should then adjust them to 75 +/- and do a Learn RC and leave them there. you should then get the F on the GSU when you flip the TX off as a check.
